Hello,
I'm trying to work out the best way to rewire my ground floor 1930s ex council flat, which is proving difficult as I have concrete floors and ceilings. What makes matters worse is the ceilings are covered in Artex which I got tested and do contain asbestos! The current wiring is ancient and is in ugly conduit. I want to remove this and chase back into the walls with new sockets and switches.
My initial thoughts were to run the cabling through either skirting or coving and chase up/down from them to sockets/switches. Then to avoid touching the ceiling, use wall lights instead. I've also got one more problem with the central heating pipes being on the outside, which is making me lean towards coving.
I'm reading a lot of conflicting information about wiring in skirting and coving. Is it ok to do? And if it is, can I use standard skirting/coving instead of ugly plastic, expensive conduit coving/skirting?
Oh and I don't really want a false ceiling due to cost, Asbestos and not really having enough room.
Any help would be appreciated. Thanks.
