Hello, doing some DIY electrics and quite capable but can't seem to find an answer on this point..I want to connect an LED cabinet light in the bathroom (Correct zone and perc rated etc..)
There was previously an electric shower, now replaced with a hot water system unit, so there is an unused cable and running into the bathroom area. However this is a 6mm² cable, I will replace the MCB with a 6amp in the CU but I want to connect the cabinet light to the power cable; can I connect a 2 core and earth cable to this gauge?
I will make the actual connection under the floor in the next room so there will be no connections in the restricted zones. Will also run the cable to the cabinet light through metal conduit under the bath (Or does it need to be under the floor?) to the wall and up a channel (Also in conduit) behind tiles to the light.
Does that seem like it would work? Advice appreciated
Paul
Paul
