Some advice please:
When on full arm you hear the exit and entry tones. How can i set this for part arm? The kids sometimes go down at night and forget the alarm is active and the first they work out the alarm was on is when the siren goes off and woken the neighbors..
On PIR's I understand that they should be set to double pole/eol- - no idea why but they are currently on 2k2/4k7(6k8) and seems to work, is this ok?
I have one door that started activating alarm approx once a night but this happens after many hours eg 5am this morning. Seems something wrong with contact. In interim is it ok if I set it for double knock? Will that help? Is this commom for contacts to wear out? It is PVC door.
One of my keypads turns alarm off when I enter user code, the other asks for confrmation. Where do I change this setting?
I have ComWifi setup for notification and am continuously getting ATS Path Fault errors. Was working fine and would happen approx once a month for last 6 months, but since 3/4 weeks ago it is happening all the time.
Is there anything I can try?
Many thanks.
Many thanks.
