Mixed brand MCBs and EICR coding
So when BS7671 effectively says that ("if under the control or ordinary persons") it must EITHER be a ('type tested', per definition) CU OR be compliant with BS EN 61493-3, what do you think it is trying to say??
I don't know, but both the definition in BS7671, and BS EN 61439-3:2012. Low-voltage switchgear and controlgear assemblies. Distribution boards intended to be operated by ordinary persons (DBO), require that a consumer unit is type-tested.
Fair enough - so (not for the first time!) the wording of BS7671 seems a little on the silly side!
I would be extremely surprised if any problems (if any) due to mixed-make (but mechanically compatible) devices did not fade into total insignificance in comparison with problems due to imperfect connections to the devices (even if all of the same, 'correct', make).
Yes, your theory is probably correct, but, if parts come from different manufacturers, you cannot assume that they are 'mechanically compatible' just because it is possible to fit them together.
Fair enough. When I said 'mechanically compatible' I was talking about a situation in which they are dimensionally identical and "fit together" - but I don't doubt that that leaves some theoretical scope for more subtle types of 'mechanical incompatibility'.
despite (as stillp will tell us) the theoretical possibilities
OK, what about the known (perhaps not to you) facts?
If someone has some "facts", I would love to see them.
I don't know if it has been decided before - but
do the manufacturers use the same criteria for there type testing (another silly phrase) and so all items could be mixed if they will fit - so they make them a different size so that they won't. That is, for example, all capable of withstanding a certain temperature next to them etc.
If not, some must be inferior to others. Which manufacturer uses the best type testing?
No doubt you would. Not sure about "facts", but I have some facts. Perhaps I'll post them when the court case finishes.
That might be interesting, but it presumably relates only to one incident. The facts I would be interested in seeing would be those relating to the incidence of serious problems due to mixed-make devices (which 'fit') in a CU.
Well today I found the solution to the photo I posted earlier in the thread. The opposite way around though, Eaton into a Wylex board.
Gotta give the guy points for thinking outside of the box
