- Joined
- 11 Jan 2004
- Messages
- 47,092
- Reaction score
- 4,089
- Country
In my entire three decades, I only ever got called out to one consumer unit that started melting then smouldering due to a loose connection on a shower MCB.
I think I agree with that, the overheating always seem to be the isolators loose joints.In my entire three decades, I only ever got called out to one consumer unit that started melting then smouldering due to a loose connection on a shower MCB.
I imagine that most of us have seen CUs that have been thermally damaged, as you say almost invariable due to loose joints.I think I agree with that, the overheating always seem to be the isolators loose joints.
I was quite surprised when I found that some CUs are made of thermoplastic.I witnessed one when I was a student. The landlord had upgraded the shower over the summer; one of the flatmates was using the shower for the first time and the rest of us smelt a burning plastic smell from the cupboard under the stairs. On opening the cupboard door, we saw a molten plastic CU, with the plastic literally dripping off and the bus bar exposed.
I did attend a house fire, but the seat of the fire was not the CU but the CH pump that had jammed and overheated, setting fire to a load of plastics that were stuffed around it in the cupboard.I wonder if anyone here has ever come across a case of that actually happening?
Indeed. I was unaware of thermoplastic CUs and.like you,m would not have expected there to be any.I was quite surprised when I found that some CUs are made of thermoplastic. IME accessories are usually made of thermosetting plastics like ABS or Bakeite, which will char, but not melt or flame.
My understanding was that it was the LFB who forced the change to happen - and remember they appear to be an organisation which uses 'electrical' as the scapegoat 'cause' when they can't actually determine what started the fire.IIRC it was the LFB that wanted the change to happen
that's not how I heard it. What I heard was that the LFB 'forced' the change on EIT/BSI, against their wishes, by threatening to take legal/political action against them if they didn't agree to do it.and of course the vested interests who update 7671 latched on to it to help justify the next revision of the regs
Indeed this is something I have encountered while installing and some have proved very tricky to avoid... but I hope I realised each one during the tightening process.It did seem the problem was some terminals were not forced open, and one could fit a MCB etc, where the bus bar tag was the wrong side of the clamp, causing a poor connection which resulted in over heating,
and the metal consumer unit was a knee-jerk reaction to this problem. But with a TT supply we also have the problem that the consumer unit is before any RCD, so a fault can cause a consumer unit to become live. Unlike a TN system the fuse will likely not rupture.
So there are problems with both plastic and metal consumer units, it is really down to a risk assessment. Using the special glands the metal can be installed safely, but also ensuring the tags are in the terminals correctly also plastic can be installed safely.
Using a torque screwdriver, one looses the feel, and easy to make errors.Indeed this is something I have encountered while installing and some have proved very tricky to avoid... but I hope I realised each one during the tightening process.
At least under the 17th you could still use plastic CUs, as long as they were mounted within a non combustible enclosure...
