Seems to fit though, so it must be OK...
Well today I found the solution to the photo I posted earlier in the thread. The opposite way around though, Eaton into a Wylex board.
Gotta give the guy points for thinking outside of the box
Hmmm. I can't actually think of any way in which one could obtain an estimate of the probability of these sort of events occurring other than on the basis of 'historic data'!In any case, history is not a guide to probability.
Are you deliberately trying to introduce confusion and 'tie me in knots'?What sort of events? How many fatal incidents are you aware of that are due to undersized shower cables? Probably none. Does that prove that it's OK to install too small a cable? (Or too big a shower?)
I then said that I would be very interested to hear of any facts about the issue (which, I agree, certainly aren't currently known to me) I'd been discussing, and you have since been evasive about what those facts are, or even what they relate to.stillp said:OK, what about the known (perhaps not to you) facts?
How does the DIN rail system tell you whether it was a DIYer or a rough spark that did it?Well today I found the solution to the photo I posted earlier in the thread. The opposite way around though, Eaton into a Wylex board.
That looks like a DIY bodge job to me! - I thought a key feature of the din-rail-mount-system fusebox, was to enable the easy identification of attempted DIY or other subsequent modifications to installations, after their original installation date!
I realise this, as I've already mentioned. Still doesn't mean it was done by a DIYerThe trouble is that the lever will be Down for On, which is both dangerous and confusing for the layman, hence the DIY suggestion, and of course against the Type A board Din-Rail-Mount system standards, where UP is ON and Down is Off. This standard is internationally recognised, even in Mainland China (look at Alibaba and the circuit breaker pages!).
Applying the highest standards of professional responsibility and duty of care, do you KNOW that they fit properly and do you KNOW that there CANNOT EVER BE ANY problems from mixing?The facts I would be interested in seeing would be those relating to the incidence of serious problems due to mixed-make devices (which 'fit') in a CU.
Applying the highest standards of professional responsibility and duty of care, do you KNOW that they fit properly and do you KNOW that there CANNOT EVER BE ANY problems from mixing?I was waiting for that, and almost pre-empted it! I'm talking about 'common sense identical'.
No, that's just a side benefit!Are you deliberately trying to introduce confusion and 'tie me in knots'?![]()
I don't think I've been evasive. I was pointing out that there are facts about the possible dangers of mixing products from different manufacturers, that are known to engineers in the business of design and manufacture of MCBs and CUs. I have no doubt you would be interested in those facts, but I'm not going to post any further information, one reason for which is that I'm currently advising on a legal issue resulting from the supply of mismatched protective devices.I then said that I would be very interested to hear of any facts about the issue (which, I agree, certainly aren't currently known to me) I'd been discussing, and you have since been evasive about what those facts are, or even what they relate to.
Of course I don't. Why on earth do you think that (as I said above) I would be interested in seeing "the facts" (which stillp rightly indicated I am unaware of) about the incidence (whether zero or greater) of any such problems?Applying the highest standards of professional responsibility and duty of care, do you KNOW that they fit properly and do you KNOW that there CANNOT EVER BE ANY problems from mixing?The facts I would be interested in seeing would be those relating to the incidence of serious problems due to mixed-make devices (which 'fit') in a CU.
Not if the danger really is a demonstrable fact. If it is known that a cable of a certain CSA will definitely overheat seriously if a certain current passes through it, then one doesn't need any in-service data to know that such use of such a cable would be dangerous. Similarly, if it were known that a certain combination of devices of different makes in a CU would definitely (at least, commonly) result in serious overheating, or other malfunction, of one or more of the devices, then one would not need any in-service data to know that that combination of devices (and maybe other mixed-make combinations) was dangerous. However, if all one has is a theoretical argument as to the mechanism whereby a certain set of circumstances could/might result in some danger, then one needs data in order to quantify the risk of that 'potential danger'.I was trying to demonstrate that a history of incidents is not necessary in order to know something is potentially dangerous.
Maybe I am wrong. If these engineers really do have 'facts', then I might change my views. In other words, if they could show me empirical evidence that a certain combination of different brands of devices in a CU resulted fairly consistently in something dangerous happening, then I would certainly take notice of that.I was pointing out that there are facts about the possible dangers of mixing products from different manufacturers, that are known to engineers in the business of design and manufacture of MCBs and CUs.
Fair enough. Needless to say, without those facts, whether they come from you or elsewhere, I really cannot discuss this topic very intelligently.I don't think I've been evasive. I was pointing out that there are facts about the possible dangers of mixing products from different manufacturers, that are known to engineers in the business of design and manufacture of MCBs and CUs. I have no doubt you would be interested in those facts, but I'm not going to post any further information ....
