Hi All,
I have bought a house with an 8mm microbore system. I’ve checked under the floor boards and can see that the 4 downstairs radiators are run off a 22mm x 4 x 22mm manifold. But conservatory radiator is run off a 22mm x 10mm x 22mm T-joint on the flow side and the same back to the return, about 5 feet form the manifold. The 22mm pipes run more or less parallel in a loop. Initially the TRV value on the conservatory was stuck, so I gave it a gentle press and wiggle and got it to work to about 40%. Even turning off the all the radiators downstairs has little increase.
My question is the conservatory radiator is about 5 meters from the T’s. Will this have a big effect or should I look to change the manifold for a bigger one and connect the conservatory to that. Or should I change the conservatory valves and see if the problem lies there.
Any help is appreciated not only for me but so I can discuss it with a plumber should I get one. I added some fernox 400 cleaner a few days ago just to ensure the system is clean before making any changes.
PS. The boiler is only a few months old.
