So I've recently moved into my property - mid terrace Victorian.
Due to the small kitchen the out house about 20ft down the split garden has plumbings for washing machine - no problem saves on noise anyway.
However the water pressure is less than terrible in the outhouse. average water pressure should be 1l per 7-10seconds it takes in excess of 1min to get 1l.
All of this results in my washing machine giving me an error code (for incufficiant water) every time I use it.
The out house has its own stopcock I turned it off cut back till was just a few mm of pipe left to make sure it wasn't existing pipe work causing the issue and pressure is still bad. So assuming it's the stopcock to be the issue - I turned the water off at the mains (in the street) and to my surprise this water is still flowing (albeit slowly) the rest of the house is off. I've hunted high and low in and around my garden for another supply for it.
So my question is - is there anyway I can change the stopcock without turning off the mains? And also is it likely this is a free water supply? In which case I really want to get it working.
