I have a Trition Aquatronic 3 shower 9.5kW which has been installed for around 6 months.
My problem is that after a period it goes cool for about 10 seconds and then returns to normal. The water flow rate remains the same so I'm sure its not caused by someone turning on a tap etc (or washer etc). It is set on heat setting 2.
It is as though the shower temporarily turns to heat position 1 and then returns back to full power.
I suspect that there is some sort of fault with the heating unit. I have checked the connections and all are good. The wires to the switch are also sound.
Has anyone else experienced this problem.
thanks
Steve
thanks
Steve
