Several months ago we had a new en-suite fitted however we haven't used it until about a month ago, we weren't living there.
The wall was built out with a timber frame and plasterboard then tiled, toilet to the front with a concealed cistern.
I had noticed a very small damp patch on the bedroom wall roughly behind the toilet but since moving in it has gone a lot worse.
Bathroom fitter came back yesterday and took the toilet off and it was very wet inside the cavity. Bathroom fitter said he couldn't see any signs of a leak and suspected it was condensation but was surprised that condensation would be so bad.
Looking at the pan connector last night I found a slit around 15mm long obviously a leak.
My question is now that we know that the damp is due to a leak should I push for the tiled plasterboard to be replaced and risk the tiling not being as good as it is a repair or should it all dry out and be OK (bearing in mind it has been toilet waste that has been leaking out)? We can't do much about what has soaked in to the breeze blocks!
Cheers
Simon
Cheers
Simon
