Fence on supporting wall
11 Nov 2008
Newcastle
I live on a corner plot semi detached, my neighbours land is on higher ground than my house so there is a supporting wall abt 5 1/2 ft high on my land which divides our gardens at the sides of our houses.
Obviously I am overlooked from my neighbour on the higher ground so I would like to build a fence abt 5ft high ontop of the supporting wall I would need to add some brick pillers to the wall so support the fencing
Would I need planning permission for this.
What are you going to put in place to prevent strong winds from blowing the fence (and pillars) over?
I am not doing the job but i am sure the bricklayer doing the job will make sure the pillars wont blow over
How wide is the wall presently? There's no point obtaining PP for a pile of rubble and broken panels.
The retaining wall is two bricks wide in very good condition there is another row of bricks inside this wall which was the original retaining wall
Anything over 2m high would need planning permission. But as mentioned unless you pan to rebuild the wall and start again it will fail (ie in a potentially catastrophic way) at some point.
Can I speak to planning officer about weather I need planning permission or not without all the hassle of submitting for permission when I might not need to
Ok can you explain why it would fail I cant understand the logic of your point if the job is done properly
https://www.planningportal.co.uk/info/200130/common_projects/20/fences_gates_and_garden_walls
Why do you think you might not need to?
Because my garden ground level is at the bottom of a 5 1/2 ft retaining wall at the boundary with my neighbour and his garden ground level is 12" below the top of the wall, I am well overlooked from neighbours higher ground and have no privacy
Your privacy isn't the issue. You wish to build a wall/fence structure in excess of 2m so you need to apply for planning permission which may or may not be granted.
How about an off the wall suggestion (pun intended)
Talk to your neighbour and get them to install a fence on their side.
The posts will then go in the ground, and not have to be attached to the wall.
Obviously you might have to offer to pay, and they might not be to happy losing a strip of land, but the fence will be on their land, and under 2m heigh on their side.
From previous experience of my neighbour he will not want to because it might reduce the amount of sun he gets on his garden at certain times of the day, but I have to put up with him growing high trees in his garden blocking sunlight to my garden :evil:
