K
Klaus_K
Hi, I am in the process of replacing the 'O' rings on my bathroom taps. I've removed the tap heads and the retaining nut that sits above the 'O' ring. I have also removed some PTFE tape that I had used as a temporary fix in the past. However, underneath this is a black ring of some kind, that I'm having real trouble removing
The reason I need to remove it is that when I try to put a new O ring in, there isn't enough thread visible for me to be able to screw in the retaining nut. This makes me suspect that the black is the old O ring, compressed down after years of use.
Can anybody confirm if this an old rubber 'O' ring, that I can safely rip out (destroying in the process) or is this an important part of the tap that I mustn't damage. I hope it's not the latter, since I've already done quite a bit of damage to it
If I do need to remove it, can anybody suggest the easiest way of doing it? I've tried attacking it with the point of a bradawl, and a small screwdriver, but with not much impact.
