- Joined
- 11 Jun 2016
- Messages
- 52
- Reaction score
- 1
- Country
Hi all
I have run a wall light from the ring main via a 3amp fused switch in the past which I believe is compliant with regs.
My questions is, if I wanted to run 2 independent lights (one either side of my bed) can I spur off one socket to a fused switch and then run a separate cable to each of the 2 switches (if so, is a 3 amp fuse still sufficient)? Or should each light have its own fused switch?
...Or am I missing something? Taking a live feed from the lighting circuit is not really an option in this case.
Thanks in advance.
Thanks in advance.
