i am going to remove my two living room large light fittings and replace by 3 daylight LED downlighters at each place spaced out across the room width.
each of the existing light fittings are on their own switch via a twin switch at the doorway
i will want each switch to bring on one set of 3 LED lights
the size of the existing hole co-incidentally is 90mm which led me to think i would fit downlighters which require that opening size whatever wattage that may be
the room is 7M long by 3.6M wide
how should i wire each group, the central one has the existing LNE wiring in place in pvc white flexible cable
i see deals with lights in packs including led driver
https://www.amazon.co.uk/Recessed-L...26163&sr=8-11&keywords=led+downlights+ceiling
and
http://www.toolstation.com/shop/p56467?table=no
please may i have advice
..edit....these look interestng
cheers
geof
and
cheers
geof
