splitting double insulated lighting circuit
Apropos another thread as well.
Not disrespecting the OP; it's not his job nor his fault as the manufacturer's do the same but this shows the confusion caused:
We do know what he means because of the thread.
Lights are non-fire rated low voltage MR16s with individual transformers...I was planning to change to mains (no transformer) fire rated GU10s.
So - low voltage MR16s are to be changed to mains GU10s.
May not have to do anything, then.
You have STILL got it wrong.
EXTRA low voltage GU 5.3 MR16s are to be changed for mains GU10 MR16s.
GU etc is the base, MR etc is the size in eights of an inch.
No I haven't; that is what the OP wrote and the point I am making.
Mains GU10 lamps ARE (or can be) low voltage MR16s
OK, but he also said his low voltage MR 16s had individual transformers. So more info required, isolation transformers?, maybe 120V lamps, but certainly not 12volt.
Who's the one on this forum always going on about transformers, and what they should really be called?
is?
Or is called?
I'm in the UK, so have no more than a passing interest in foreign countries such as the 26 counties of the Republic of Ireland.
