Yes.Thank you, I asked at the plumbers merchants I use this morning but they don't sell them. Does filing down the iso valve not give it a flat enough surface?
Is that how you do it?Yes.Thank you, I asked at the plumbers merchants I use this morning but they don't sell them. Does filing down the iso valve not give it a flat enough surface?
if using a number 3 is it best having the end that connects to the copper in compression or solder? Guess doesn't matter. Just want as less fittings behind the pedestal.If using a 1/2 male. Does it matter.if.the.other end.is.compression or.solder? Does no one.screw them.on to an iso valve any more then?
