Flexi screwed on to iso valve
30 Oct 2014
Blackpool
Isit ok to screw the female end o a flexi on to an iso valve. Or is a 1/2 male to 15mm compression needed? I could file the end of the iso valve to give it a flatter surface?
As above, connecting the female end of a flexi straight onto an iso. valve isn't recommended. Whenever I have this situation, I use a tap tail adaptor. One end fits into the iso. valve, secured by an olive and compression nut. Other end has a thread, allowing the flexi to be screwed on.
http://www.toolstation.com/shop/p14081?table=no
http://www.toolstation.com/shop/p63663?table=no
Thank you, I asked at the plumbers merchants I use this morning but they don't sell them. Does filing down the iso valve not give it a flat enough surface?
I have had the same problem. I had a leak just as Dan Robinson said. I asked at Wickes and Plum centre. They had no suggestions. I did not think until i saw the fittings on the link, but I have loads of radiator tails. Would they do the same?
Use a fibre washer .. Isolation valve seating is no different than a tap seating whereby we use a tap connector with fibre washer.
Riley,the link that whitespirit provided for you is from Toolstation.
If you google that name and find your nearest branch ,you should get those items
If using a 1/2 male. Does it matter.if.the.other end.is.compression or.solder? Does no one.screw them.on to an iso valve any more then?
if using a number 3 is it best having the end that connects to the copper in compression or solder? Guess doesn't matter. Just want as less fittings behind the pedestal.
