After teaching myself the necessary skills I put in a new kitchen just over a year ago and installed new wiring throughout. It was all inspected and the electrics were signed off by a qualified electrician. The only thing I didn't finish wiring up was the LED mood lighting. The main wiring was completed all the way to the power transformer that sits above one of the kitchen units (so as good as finished), but the LED strip lights themselves weren''t installed and wired up to the transformer - a job I thought I'd complete after a couple weeks break.
80 weeks later (!) and I've finally gotten round to completing the job. I've installed all the LED strip lights and they work a charm and look good, but I've uncovered a small but frustratingly odd issue. The light switch is back to front.
My kitchen's primary light socket is a 2-way 3 gang light switch. Only the first gang/switch operates on a 2-way circuit though (the main kitchen ceiling light can be turned on at the primary switch and at the other end of the kitchen on a secondary 2-way switch). The second gang/switch operates as a 1-way switch to operate a pendant light, and the third gang/switch operates as a 1-way switch to operate the LED mood lighting (specifically to provide power to the aforementioned power transformer).
All the switches work, but the third switch for the LED mood lighting is back to front. To keep things simple all the lights are supposed to be OFF when the switches are in at the top and out at the bottom. But the LED mood lighting switch is ON when it's in that position.
The brown wire was in 'COMMON' and the blue wire was in 'L1'. I thought that the brown and blue wires must simply be round the wrong way, so I swapped them round, but nothing changed?! The switch still operates the exact same way and the LED lighting is ON when the switch is in the OFF position.
I've included a few photos of the 2-way 3 gang light switch in question, and the LED mood lighting power transformer, just to better explain the wiring.
The brown and blue wires are the 2 nearest the camera which serve gang/switch number 3.
Is there a simple way to get the switch to operate like it's 2 sister switches and be OFF when the switch is IN at the top and OUT at the bottom? At the moment the lights are all OFF when the switches are positioned as in the photo below.
The issue seems like it should be so simple to resolve (and maybe it is!?) but I just can't get my head round it.
Thanks very much.
Thanks very much.
