Concrete Calculation questions
10 Dec 2009
Middlesex
Im trying to calculate the amount of concrete by weight that i will need for a small job and have some questions that you guys might be able help and advise with.
1. from what Ive researched, 1 cubic meter of concrete weighs approximately
2,406 kg.
Does this figure refer to the concrete in its mixed form ready to use?
(i.e all components including water added and mixed up)
2. Based on the above being correct can you advise me if ive got the following calculation correct:
I have a space measuring 30cm long x 40cm wide X 40 cm deep.
0.3 x 0.4 x 0.4 = 0.048 cubic metres
2406 x 0.048 = 115.48 Kg of mixed concrete
If the base calculation is correct I will adjust it, adding 5-10% to cover any discrepancies with measurements/mixing and spillages etc.
Thanks in advance
Rob
Are you buying your concrete by weight?
Not exactly but I'll be buying the bags of cenent, sand and aggregate from b n q or somewhere similar so yes I'll ultimately be able to work out the weight based on the bag weights.
And when you put your 25kg bag in the mixer and add your cement and water, how much concrete will come out in weight?
Cement weight + aggregate weight + water weight.
I forgot to add. 1litre of Water = 1 kg
I'd just get a bag of cement and 6 bags of ballast.
Yeah, think about the size of a bag of sand/gravel and how many would fit in that space. 5? 6?
The cement and water adds to the weight but not to the volume
