    Dismiss Notice
Concrete Calculation questions
Discussion in 'Building' started by 600rob, 4 Sep 2016.
  1. 600rob
    600rob
    10 Dec 2009
    661
    Thanks Received:
    15
    Middlesex
    Country:
    Im trying to calculate the amount of concrete by weight that i will need for a small job and have some questions that you guys might be able help and advise with.
    1. from what Ive researched, 1 cubic meter of concrete weighs approximately
    2,406 kg.
    Does this figure refer to the concrete in its mixed form ready to use?
    (i.e all components including water added and mixed up)
    2. Based on the above being correct can you advise me if ive got the following calculation correct:
    I have a space measuring 30cm long x 40cm wide X 40 cm deep.
    0.3 x 0.4 x 0.4 = 0.048 cubic metres
    2406 x 0.048 = 115.48 Kg of mixed concrete
    If the base calculation is correct I will adjust it, adding 5-10% to cover any discrepancies with measurements/mixing and spillages etc.
    Thanks in advance
    Rob
  2. Sponsored Links
  3. tomfe
    tomfe
    27 Aug 2014
    1,262
    Thanks Received:
    160
    Country:
    Are you buying your concrete by weight?
  4. ^woody^
    ^woody^
    3 Sep 2006
    32,783
    Thanks Received:
    4,429
    West Mids
    Country:
    More to the point, does anyone sell it by weight?
  5. 600rob
    600rob
    10 Dec 2009
    661
    Thanks Received:
    15
    Middlesex
    Country:
    Not exactly but I'll be buying the bags of cenent, sand and aggregate from b n q or somewhere similar so yes I'll ultimately be able to work out the weight based on the bag weights.
  6. 600rob
    600rob
    10 Dec 2009
    661
    Thanks Received:
    15
    Middlesex
    Country:
  7. ^woody^
    ^woody^
    3 Sep 2006
    32,783
    Thanks Received:
    4,429
    West Mids
    Country:
    And when you put your 25kg bag in the mixer and add your cement and water, how much concrete will come out in weight?
  8. 600rob
    600rob
    10 Dec 2009
    661
    Thanks Received:
    15
    Middlesex
    Country:
    Cement weight + aggregate weight + water weight.
    I forgot to add. 1litre of Water = 1 kg
  9. Sponsored Links
  10. noseall
    noseall
    2 Feb 2006
    41,909
    Thanks Received:
    2,615
    Staffordshire
    Country:
    By weight????:confused:
  11. tomfe
    tomfe
    27 Aug 2014
    1,262
    Thanks Received:
    160
    Country:
    I'd just get a bag of cement and 6 bags of ballast.
  12. 600rob
    600rob
    10 Dec 2009
    661
    Thanks Received:
    15
    Middlesex
    Country:
    Thanks mate for your input.
  13. ^woody^
    ^woody^
    3 Sep 2006
    32,783
    Thanks Received:
    4,429
    West Mids
    Country:
    Yeah, think about the size of a bag of sand/gravel and how many would fit in that space. 5? 6?
    The cement and water adds to the weight but not to the volume
  14. kazuya
    kazuya
    13 Sep 2012
    308
    Thanks Received:
    60
    Nottinghamshire
    Country:
    15kg of cement, 30kg of sand, 56kg of gravel and 14 litres of water
    • Thanks Thanks x 1
  15. 600rob
    600rob
    10 Dec 2009
    661
    Thanks Received:
    15
    Middlesex
    Country:
    Cheers buddy!
  16. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
