Hello,
Hopefully someone will be able to assist me. Please note I have read through other posts on the subject but I am still not 100% sure...
I have a 2 way light switch system to my upstairs bathroom. One in the hallway and a second one in the master bedroom. This is because there is an extra door from the bedroom to the bathroom. I assume this silly solution was to pretend the master bedroom is en-suite
I'm now getting rid of this extra door to make space for a fitted wardrobe so I would like to put a blanking plate on the additional switch.
If possible, what I'd like to do is connect whichever wire need connecting, tape over any remaining ones and fit a blanking plate.
The switch is a 2 gang. One gang for the light and second for the bathroom fan:
Why would you touch the switch you want to remain ? All you have done is confuse the issue
on the switch you are removing just :
Connect the bath common and bath L1 together.
Connect the fan common and fan L1 together.
If the switches on the switch you wish to keep operate upside-down just swap the L1's for the L2's
The two redundant 'L's should be put into separate connectors and made safe.
Regards,
DS
Any advice on what to do with the wiring to blank the switch would be appreciated. Thanks!
