All,
I'm new on here but going through a bit of a planning nightmare at the moment and would really appreciate any guidance or help the community can offer!
I'll try to keep this brief but want to give the relevant details so please bear with me:
I recently bought a 3 bed mid-terraced property and received advice (clearly not very good advice) that I would have no trouble widening the kitchen at the rear either through planning or PD. I have uploaded a file showing the existing and proposed plans to illustrate what I would like to build.
This is not a large extension - it measures 4.6m long x 1.4m wide and is single storey - however it is long enough to require a neighbour consultation scheme if using PD. The other complication is that it would be built up to the boundary with my neighbour whose house is a mirror image of my existing plans (including window placements). This means that I would be filling in my gap at the side but my neighbour would be retaining his which is where I have had difficulty.
I took advice and had the extension designed with a pitched roof and an eaves height of just 2.3m by the time it reached the boundary to minimise any impact on my neighbour. I say just 2.3m because there is a pre-existing boundary wall measuring 1.9m so the change in view, outlook etc. is quite small. I discussed this with my neighbour, got his consent, and submitted my PD application assuming all would be fine.
My neighbour however, has dementia. He forgot our conversation, got surprised by a council notification, and objected. The planning officer, after first telling me she couldn't assess the objections and had no power to approve the PD once an objection had been lodged, then decided to reject on 3 grounds:
Starting with #2 - surely there can be no impact on light from this extension when there is already a 2 storey house already blocking light from this direction and which crosses the 45 degree rule? Not to mention the pitched roof design and low eaves height.
#3 - I guess there might be some effect on outlook but noone has ever clearly explained to me what change in outlook means so I'm having trouble assessing this. Whatever it is, surely 40cm is quite small and wouldn't have any material impact?
I understand appeal is one option but this takes at least 3 months and I don't really have that time. Any advice greatly appreciated!
If you've read this far, thank you for taking the time and look forward to hearing your thoughts.
- "Excessive" depth (the actual word that was used)
- Light: citing 45 degree rule drawn from window from existing dining room - see attached plans
- Outlook: apparently raising the height of the wall by 40cm would have an unacceptable impact on my neighbouring property's amenity (still not clear what this means)
