Are you talking about linear voltage regulators or switching voltage regulators? I understand that the latter are more efficient but emit much more RF noise. I'm not sure I would want to get audible interference on my AV systems. Is that a real world risk?Ah, OK - I'm ignoring MikeFromLondpn. I forget why, he must have posted something rude or otherwise annoying at some point in the past.
I now see his post number 61 where he makes various comments, which I guess I should respond to:
- It clearly won't get any hotter than a resistor doing the same job.
- With a resistive constant load like an LED it will work fine without a decoupling capacitor.
- People niormally use series resistors to regulate LEDs because they have a known supply voltage and a known load current. In this case we have an unknown supply voltage and an unknown load current, but a known load voltage.
- These devices cost pennies, and the implementation is very straightforward with no need to guess or even measure anything - so it's far from overkill.
I guess the other point is that if it all works fine without a voltage regulator then what exactly would be the benefit?
