- Joined
- 13 Nov 2016
- Messages
- 4
- Reaction score
- 0
- Country
Hi guys, any help/advice you offer would be much appreciated.
I'm upgrading a couple of plug sockets in my flat from white plastic sockets to metal plate as follows:
Swapping the 3-gang 2-way switch on the left is fine, that's easy to change and I've had no problems.
The trouble I'm having is swapping the 2-gang 2-way switch for the LED dimmer. Although the switch and dimmer are both 2-way this is the only location where the lights can be turned on or off.
I have two track lights each with x5 6W GU10 LED spotlights so a max requirement of 30W per track. Each track is controlled on and off by each one of the gangs on the socket.
The LED dimmer switch is rated to a maximum of 100W (min 5 watts).
The back of the 2-gang 2-way switch with wires in situ looks like this:
The back of the dimmer switch looks like this:
I've wired up the dimmer as follows:
Everything works but my question is have I wired things up correctly?
The COM wires from the old switch are now fed into the L terminal of the new dimmer
The L1 wires from the old switch are now fed into the wavey terminal of the new dimmer
Also, I've noticed when I turn the lights off some of the LEDs look as though they're still on, very dim but still on. Is this normal?
Again, many thanks in advance, much appreciated.
