- Joined
- 1 Apr 2016
- Messages
- 13,606
- Reaction score
- 550
- Country
Nothing in your picture shows an isolation valve. Fitting them is simple.
Shouldnt make a lot of difference, depends if the flexi`s are out of sight, fitting an isolation valve would give a slight bowing to the flexi, if you want the flexi`s upright then chop a section off the feed pipes, You are going to have to turn off the water supply to fit them anyway. decide then.
So fitting the isolation valves will be just a matter of turning off the supply, unscrewing the flexi and then screwing in an isolation valve and then screwing the flex into the isolation valve.
Surprised nobody has commented about using the correct fittings and the dangers of tightening a flexi with a flat rubber washer to a male iron olive fitting.
Depends @just pumps , if it is a male iron then it has a flat face on the 1/2" end, perfect for the rubber washer.
If it's a straight coupler, then both ends are fluted to take the olives, in those instances I file the edges down before using a flexi.
