Gu10 lights stopper working!!
13 Dec 2011
Cumberland
Happy new year all.
we have a loft converted to a bedroom and have 8 gu10 spotlight fixtures in there.
There is a dimmer switch at top of the stairs and a standard switch at the bottom of stairs.
I tried fitting led bulbs into them but they just flickered so i replaced those with gu10 20w standard bulbs.
Now none of the lights in that room work (but bulbs work in other units throughout the house)
Could it be the dimmer switch that is causing the problem or not?
Any help is much appreciated.
Picture is of the dimmer switch at top of the stairs (for wiring purposes)
Take a picture of the back on the dimmer before you replace as a aid to wiring the replacement dimmer or switch.
Your replacement must be suitable for 2way switching.
Does the lighting for the loft come from an existing lighting circuit or was a new circuit added?
HNY
DS
HNY
DS
I honestly couldnt tell you what curcuit its on. At a guess id say it was spurred from the bedroom below. This was done probs 15 years ago.
Question was more aimed at could the dimmer be the cause of the lights not working even if the other switch is ok?
