Three Phase question
Short answer, get a single phase instant hot water heater (that is suitably rated for where you are going to wire it into - unless your getting additional wiring done)
I would like to get a DBX18, My question is by the looks of it I can not install it as like you would say a 7kw shower as its a three phase unit. what would i need to do exactly?
Unless you have a 3-phase electricity supply (which is very unlikely if you live in an ordinary house) there would be no sensible or cost-effective way of installing it. If you want such a product, you need to find a single-phase one.
Yes aged with above, you can get single phase instant heaters up to about 11kw, so no need to worry about inverters etc.
Hi no i have a standard home consumer unit i was hoping they would be a way round it ie. maybe a separate RCD box and breaker, and no other unit if you look at the spec sheet can fill a bath. I want to take out my cylinder and header tank and replace with the DBX18.
Why not get a real boiler? can even get electric combi's if you don't have gas.
As has been implied, if you have an ordinary single-phase supply, then that's what you've got. The only option would be to get an electrical 'box of tricks' (an "inverter") to generate a 3-phase supply from your single-phase one - but I think you'd probably find the cost prohibitive, not to mention the additional complexity etc.
Also, do you understand how expensive hot water heating is (to run) - particularly if you want to "fill a bath" (such a device would fill 50 baths, if you had enough time and money!)?? Do you not have gas?
Hi John,
Unfortunately there is no chance of my property having gas, I dont think the DEX has a quick enough heater to cope with a bath
You cannot install an 18kW water heater on a standard domestic electricity supply.
Even if you had 3 phase and installed one, you are still looking at 15 minutes or more to fill a bath to a moderate level. Even longer in the winter.
What is wrong with the cylinder?
Has anyone tried putting two 11kw heaters in parallel? That would get you a good result, although you'd be taxing your incoming supply in most cases.
Fair enough - I have the same problem (no prospect of piped gas). However, oil, or even LPG, is cheaper than electricity for (real-time, 'peak rate') space heating or water heating.
What is your present set-up - are you using an immersion heater to provide hot water? If so, does it use off-peak electricity?
As for the bath, you're up against physics. No electric heater capable of working off a normal domestic electricity supply would be powerful enough fill a bath in a sensible period of time. Even a small gas combi would probably be around 30 kW.
I think that 'taxing' is probably somewhat of an understatement! I don't think a DNO would be happy (i.e. would not give permission for such an arrangement - if they were asked, as they ought to be!).
DBX18 can be connected to a single phase supply, but NOT a standard domestic install. Its around 78amps on a single phase, 26amp per phase if on separate phases. This is no good for a typical home.
