It was to keep it from dripping while I went to get a JB. I came across it while I had the floor up for another reason. I put the floor down to prevent anyone falling down the hole while I was gone.
How odd there must be miles and miles of imperial cable in Devon with green goo, I've come across loads of it in the past year. Strangely I've never seen green goo on a metric cable!
Blimey - I don't think I'd have bothered to cut slots in the sides of (and thus ruin) a container like that, or tape the lid down, for such a short-term use. Even if I had to go and buy a JB.
I get umpteen such containers from the takeaway nearly every week They are very much 'disposable' ( keep and use as many as I can, but there is a limit!)
Have you done any tests to see what oven temperature they will withstand? I always like to give my takeaways a bit of a temperature boost, and I miss the old aluminium dishes.
The lid looks an awful lot like he used a "proper" storage container, not a disposable takeaway one..
Maybe my position is skewed by the current lack of a working oven apart from our combination (which is full sized), so microwave ≡ no hot box, which is pigging useless for things like onion bhajis, breads...
Well, for a start, cable is generally considered to have a serviceable life of 30-40 years. (Perhaps much less if you ask the manufacturers.)
The reality is that it does not last forever and degrades with use. This wiring is 50 years old or more and therefore should not be considered to be at the pinnacle of its career.
That's essentially a repeat of BAS's question, not an answer to it. What characteristics or features do you believe will have degraded? Conductivity, IR and apparent flexibility certainty seem to be maintained for very long periods.
We have 1970s PVC and the main issues are it's much stiffer than the new stuff, the colours are wrong, and it's hard to strip in places, the insulation stocks to the conductors. Apart from that seems like it's fine!
