In my area, you pay the fee for a building control notice, and they just pass the fee over to a Leccy company that will come in and just test the installation, so the design will have been done by the buider/diyer, not the tester. I don't know if they are then happy that there is just an electrical safety certificate, and aren't bothered about the design, but it does seem odd.
I was reading down the recent posts, and as I got to the "an electricians job isn't that complicated" I laughed and thought, boy you've just dropped yourself in it. Responses as per expected.
NAZ, read up, check the current regs, have a chat with your electrician, and then come back, and a little of the pique may have subsided by then. I will finish by suggesting you just bed the cables in, as you're never going to have to take them out again if you've done the job properly, and it'll be MCBs on all the circuits although some her would suggests MCBOs on the showers. The RCDs are for earth faults, and not the same as MCB. You do have a lot more reading to do I'm afraid.
THANK you, and much appreciated.
As regards to the comment, I didn't mean that their job isn't complicated, what I meant was the job for my property isn't that complicated. Come on, it is a 2 bed bungalow with couple of lights!
I will also have a chat with the inspector ( independent). I know it says something in the lines of there is a charge of £180 if the installer can't self certify the electrical work and issue the cert. So it maybe that he has an electrician who will do the testing for the £180 ?
I will also get the electrician around to have a chat and see what he says.
The kitchen ring is the latest that was added a while ago ( think about 4 yrs ago) and it is the only circuit that is on a RCBO at the moment. The rest are on MCBs including the current 8Kw shower. There are no RCDs at all in the CU apart from the RCBO.
I just don't know if I should replace the whole CU now or wait until next year when the next floor is in and then I can get more room to work on!
