- Joined
- 17 Oct 2005
- Messages
- 222
- Reaction score
- 3
- Country
It's not strongly worded - it is simply a statement of fact.
Certainly if you get someone in to do the work they must be an REC, however there is NO LEGAL EXEMPTION FOR DIY. In other words, if you are not an REC then you may not do this even if it is in your own home.
As a member of RECI and an REC I am regularly inspected, must be insured and have Wiring Rules, test equipment etc. and certain other things - also I need to have a valid QC (Qualified Certifier) Number.
But that surely is because thats your line of work?
- what about if consumer wants to take down pendant light fitting and put up a 3-way spotlight bought out of argos? - do they need to be reci registered or get an electrician in? - what about if consumer wants to change plastic light switch for a dimmer switch bought from homebase? , what if I wanted to go to homebase tomorrow and buy a 500w PIR halogen fitting , can I not install it myself, would I have to get an electrician in?
- in UK consumer can replace these things without being registered
