Bricklaying 101 - #6 mortar joints
3 Sep 2006
West Mids
Latest flyer from Screwfix.
Now, if you see bricklayers doing this on your home extension, **** them right off without delay. Tools and all.
Is the top one a pointing trowel or is it one of those finger trowels and the bottom one for cleaning buckets?
Either way, I think those guys built most of the walls you see in this section!!
The top one might be a gauging trowel, and the bottom one is a bucket trowel which is a handy tool when knocking up a small gauge in a bucket.
I use a bucket trowel when I do block work. I must retrain and do it correct way. :D
How are you supposed to get the digestive biscuits out of your teeth with those shaped trowels? Classic case of designers not understanding their product. The R&D department must be on a low budget.
I'm not a bricklayer by trade, but I do lay a few thousand bricks and blocks every year. I use a gauging trowel over a normal brick/mason's trowel as I usually work with the mortar dumped into big plastic flexi tubs where the shorter length and round nose makes it easy to get all the mortar out. Out of habit I still use one when working from a board. What is the disadvantage to using one? Is it only the speed?
They are about as wieldy as a dinner plate. Fine for scooping muck out of a container but completely bereft of any finesse.
