- Joined
- 26 Aug 2016
- Messages
- 6,830
- Reaction score
- 1,009
- Country
Assuming "ring main" literally means (ring final) circuit,
In this case the op mentioned the existing 32A breaker and the old wiring connected to it, so it leaves little doubt which definition he's using!It could well be a "new" circuit in the normal everyday meaning of the word new. it could also not be a "new" circuit according to the definition in BS7671. There is no contradiction.
A John points out, what to the lay person is a "new ring round the kitchen" could well be an extension of an existing RFC. Or it could be connected to an existing breaker in the CU. In both cases - the OP may be correctly calling it "new", but it's not "new" according to the definition in BS7671 and hence not notifiable. From the context of the question, the OP is very unlikely to know and understand the BS7671 definition of new circuit, so it's quite reasonable to work on the basis that he is using the "everyday usage" of the word "new" - but for regs compliance, you need to use the official definition.
I wasn't sure about the existing breaker bit. Existing breaker = not a new circuit according to BS7671.In this case the op mentioned the existing 32A breaker and the old wiring connected to it, so it leaves little doubt which definition he's using!![]()
Indeed, or is another one never to be seen again BAS's "help".I'm sure the op has given up on this thread and is getting on with the job already.
Please show where the Building Regulations use the definition from BS 7671.In both cases - the OP may be correctly calling it "new", but it's not "new" according to the definition in BS7671 and hence not notifiable.
But you think that their intention was that if there was a CU in place, populated with MCBs etc, and not a single mm of any final circuits, that someone could then come along and install every single bit of the rest of the installation - choose and run all of the cables, install all of the accessories and fixed appliances, and that as long as they avoided putting anything in any bathroom zones none of it would be notifiable.If you use any other definition such that adding to an existing "circuit" (BS7671 defn) is a "new circuit" (BR terminology) then just adding an extra socket to a ring would be notifiable. Given the 2015 relaxation in what's notifiable, then having nearly everything notifiable cannot be what was intended by the authors.
