I've run some cables up thru some back boxes for 240v sockets and was just putting some pvc channel over the cables (pairs - it's a ring) when I thought that it might be easier to get the grey outer off before the cables are fixed in place behind the pvc channel and up thru the grommets. Is it an issue or should a spark be able to deal with this later, without any problems after the walls have been plastered?
Thank you.
Thank you.
