Continuity bonding gas meter removal nvq level 3 question
30 Oct 2014
Blackpool
I wonderd if any one can help me with a question for gas meter removal on my nvq level 3 in plumbing. When applying temporary continuity bonding on the pipe work before removing the meter. Do I place the continuity bonding on the upstream side on the meter( side with ecv on) the the downstream side. And disconnect in reverse order? Thank you
Makes no difference at all, just make sure it's in place before disconnecting the meter until it's reconnected.
It should not really matter if the meter is still connected, as you you should still have continuity throughout.
I think logic would suggest that you apply the croc clips to the consumers side first and then to the supplier side, but if you do them simultaneously, no probs. The important thing is to check continuity does exist before and after the application.
It does matter on the assessment and danfre is right. In the real world, it makes no difference.
I guess someone was paid by the question. I bet there's one in there about which sock you put on which foot too:rolleyes:
No , it is referred too as 'service pipe' and 'supply pipe'...
Fair enough, I will make a mental note of that for the next time, I have to undertake such a task.
Thank you kindly for your informative input.
No problem , although if you're qualified to undertake such a task then you would know the correct terminology to use when referring to a service pipe and that of a supply pipe.(y)
I m qualified to undertake such work, TBH honest I have never had to use the terminology that much, just trying to explain the answer to the OP. In terms that seem logical, suppliers side (ie BG, Scottish Power etc.) and customers side (ie the user/payer of the bill)
i wouldnt imagine you have used the terminology you have only been qualified a few weeks ;)
