Replacing an old CU with a new one
Hi Aptsys
It perhaps is due to so many different things being suggested that has caused a bit of confusion :d
The plan was initially to upgrade the CU to a split CU with no RCBO but dual RCD protection. This has for now been delayed due to the leccy not doing the work and then having to do further work.
So the RCD that you have suggested, will be used to replace the voltage breaker that is currently installed between the meter and the current CU which is a mix of RCBO and MCBs. The overall circuit at the moment is only protected by the VOELCB which I am aiming to either get board to replace with an RCD type or them install a breaker in the meter box so that I can then replace safely.
Then in a few weeks time, once I am ready, I will get the CU replaced.
I was (perhaps wrongly) assuming he's be installing a split or mixed RCD/RCBO consumer unit.
I think you are right about that - eventually.
However, if it is to protect the tails because their installation method requires it - or
for personal protection until CU replacement - then it still must be 30mA.
If neither of those reasons apply, when the CU is fitted, then an upfront RCD is not required.
To begin with, it will be mainly your #2 ( Personal Protection) as currently apart from 2 RCBOs which protect the kitchen and electric shower, the rest of the installation doesn't have any RCD on it. The only protection on it at the moment is the VOELCB.
Yes it is, it's very cheap. In fact it cannot be done properly for that price, assuming they are working because they need money to live.
You have NO IDEA what is involved and how long it takes.
That quote of yours has done my head in since, and you never replied to my further question.
here is a link I found to do with pricing for EICRs:
http://www.whatprice.co.uk/prices/e...nspection-incl-certificate.html#axzz4jQDSFFfz
The most I can find on there is about £250 for a 3-bed house. I have a 2bed bungalow!
You must want this chap, then:
What does that tell you about the site and some "electricians"?
No, a bit of common sense really.
If I had a studio flat with 1 single CU with 3 circuits on it, then yes!
It was merely commenting on Phatboy saying that £150 is cheap for an EICR not knowing the size of the circuit.
It also tells me anyone can pay £500 to NICEIC and become registered with them. Unfortunately the way government has made the changes, people's perception is that by being an NICEIC member, you know what you are talking about. Some people don't realise NICEIC is a private company and not a public company!
EICRs are not typically priced on the size or type of property.
What really matters is the number of circuits and how much testing/inspection is done.
Completely agree. Which is why one should always obtain at least 3 quotes so he has something to compare against.
One might charge £500 for an EICR thinking he is not going to get any work out of it .
On the other hand, another leccy might charge £60 for one, knowing by being reasonable and friendly, it is very likely that he will get more work out of it based on the findings.
I might just go back and do the rest of my certification and then do this part time.
That doesn't make sense.
At a fixed price, surely the larger your property, the better.
OK. (I think you mean property, not circuit)
Well, sort of - there are other conditions - equipment, paperwork, insurance, previous work to inspect.
That is true and not the case.
Also true - all part of the con.
I don't think that is the reason.
Cheap EICRs - usually for residential letting agencies - are not really EICRs - and
to make a living would require one every couple of hours.
