going nuts here a bit. I'm trying to do the dims for my garden office and am doing 5x2 roof joists with firring strips on top for the pitch. I am doing 400mm centres, but this does not seem to work to get the end of the OSB (1220x2440) to end on half the joist. I've read somewhere you do 353 gaps, but this doesn't seem to work either.
Joists are 45mm wide finished size. The end of the roof / 1st joist; the sheet is flush with. The rest the sheet has to end half on the joist for support. Cannot work out the distance from one joist to the other to be exact.
Also i thought 400mm centres was so the gap between joists was 400mm for insulation fitting (comes in 400mm or proportions of that), but centres means centres so have to trim down to 355mm??? very confused, any advice appreciated.
