Why not use plaster, or a gypsum based filler, to hold it into the chase? No reaction worries then.What happens if it reacts with the plaster and causes cracking at a later stage because the conduit has moved or become loose ?
Maybe it's just me, but in my experience, that's easier said than done - at least in my hands, the cable has an 'orrible tendency to 'jump out' through blobs of plaster or filler.Why not use plaster, or a gypsum based filler, to hold it into the chase? No reaction worries then.
The OP is fixing conduit.Maybe it's just me, but in my experience, that's easier said than done - at least in my hands, the cable has an 'orrible tendency to 'jump out' through blobs of plaster or filler.
I realise that, and I haven't tried it, but I would have suspected that a similar problem might arise with conduit to what I have experienced trying to hold cable in place with blobs of plaster/filler. Given the greater rigidity of conduit, it might work better, but I feel that there still might be problems.The OP is fixing conduit.
Indeed. In the case of 'stubborn' cables (and I guess I would do the same with conduit), as a last resort I've been known to temporarily attach a few bits of wood across the chase, with some sort of padding underneath.It is more a case of making sure that the conduit is firmly bedded into something, so that everything is solid when filling the chase and making good. I usually use a form of mechanical fixing to hold the conduit into the chase, in the form of leaving a few "nibs" at the sides of the chase that make the conduit a tight fit there.
