I built the dormer below with a differing pitch to the main roof. I thought a shallower pitch would suit the dormer better than that of the (steep) main roof.Would having a dormer with a 20degree pitched roof be an issue when it's built onto a roof with a 42(ish) degree pitch?
I'm hoping to avoid having a dormer with a flat roof.
It's a little under 2200mm wide from cheek to cheek. You have to allow for about 50mm of celotex insulation across the face of the internal studs so plan this when setting out the window opening.Very nice. Do you remember how wide you built that?
Lead.What's it clad with? It looks neat.. Epdm or GRP?
True but won't be half as useful, can't you step it abit further back up the roof or wouldn't that be practical how much out were you to fall under PDThe reason I'm doing this is because we had a guy do us plans for a flat roofed dormer but they got knocked back by the council for going over the 50cu/mtr limit. I'm thinking 2 pitched roof dormers would save on volume and look better than a big box on the roof.
