My house is a 2007 build and i'm planning on removing the 3m wall between the kitchen and dining room to open it up. The wall is a breeze block support wall, supporting the upstairs floor joists only.
Plan of action
Get RSJ calculations from a structural engineer
Notify Building Control and pay fee
Hire 6x acro props and 2x scaffold board (use 3 acro's both sides of the wall supporting ceiling via scaffold board)
Remove wall
Install 2 padstones, 1 either end of the RSJ support wall with 150mm+ of room for RSJ to sit on
Measure and order RSJ and install, concrete in to place
Plan visit for building control to inspect
Make good, using fire resistant plasterboard
Does that sound like i'm doing it right? Anything obvious i should be aware of or missing?
Questions:
1. Can the padstones sit on the existing breezeblock walls from the adjacent walls at either end of the RSJ or do i need stronger supports for the padstone blocks? (one wall that the RSJ will sit on is the external wall so may be brick?) Just not sure if breezeblock is strong enough for padstone supports
2. If i want to move the RSJ into the ceiling void so its hidden, can i cut the floor joists and install the RSJ in the void then use RSJ hangers attached the RSJ to hang the joists?
Plan of action
Remove wall
Questions:
