.. I'm wondering if Brains SA might tempt him out
buthas invented his own device to collect system debris in the dead ends
It'd be easier and quicker to train a chimp FFS...![]()
Old Camberwickgreen would be better putting 6M of 8mm copper tube in a combination cylinder & defying the Laws of Physics with his hot water supply, the man's a f.cking genius!!
In the thread shaky1105 I said:The calculated external surface area of the mains fed coil is 160,000 mm² and this was achieved by forming the coil with 6.5 metres of 8 mm diameter pipe.
so you have managed to take a 4 port manifold and blank two of them off ????? think I was
about 10 stone lighter when I worked that one out
and at least one will be un-blanked when another radiator is installed .and blank two of them off
Space constraints given that fitted furniture is going there. When the system was first installed there were tees. These went through the floor going to 15mm pipes vertically down to the radiator in the room. Hence the large hole in the floor https://www.diynot.com/diy/attachments/image-jpeg.122831/why you couldn't have fitted tees
