- Joined
- 11 Jan 2004
- Messages
- 46,650
- Reaction score
- 3,894
- Country
OK....done!
That's just not the case.With a 2.5mm radial in the kitchen/utility you'd need to think about 2 circuits, or running 4mm cable in and out of each socket (and a spur would be a pain without a 35mm back box)
That's my view, other opinions are available!
He's not, but if he were then he would be creating new circuits, which would be notifiable.Regarding the running cables, if you're in england, and you know what you're doing, just cable it up as you say, either connect to the CU or don't depending what you feel comfortable
To what end?and then get the CU changed immediately afterwards.
I'll correct that for youIt's all very well trying to talk to the electrician beforehand, but I can't imagine many want to have a big debate and splitting up the work, they'll want to come in, do the job get paid and leave, no messing around.
It's all very well trying to talk to the electrician beforehand, but I can't imagine many want to have a big debate and splitting up the work, they'll want to come in, do the job get paid and leave, involvement in lying and cheating to get around the law.
ban-all-sheds, new CU as the RCD in the current one doesn't work, and as it's an obsolete MEM board, the replacement RCD and adaptor to fit cost more than a new board.
F
See above.To what end?
Thanks, I knew I forget something from the sentenceI'll correct that for you
Didn't realise it was more flexible, I thought it was a bigger size of the same material and as we know from joists, doubling the depth increases the stiffness by 8 times, so it's a bigger effect than just the small increase. Although even if it does hold, I only make it 31%stiffer and maybe two of them can squeeze through a 20mm grommet only just?.That's just not the case.
It's not an opinion. 4mm² is more flexible than 2.5 and much nicer to work.
Look how much huger it is:
Didn't realise it was more flexible... ... ...I only make it 31%stiffer
Yes, I know about the need for the CU.See above.
Indeed - and, quite frankly, the external dimensions are so similar (particularly given that they vary a bit for both 2.5mm² and 4mm²) that I often struggle to tell which is which just by glancing.With 4mm² cable, the line and neutral conductors are 7 stranded, rather than a single solid in 2.5, so it's more flexible.
They aren't that bad.rings are like marmite
And may well allow a 32A radial.Like JohnD (and, I suspect, many other DIYers), there was a time when I was hesitant to use 4mm² - since it sounded much bigger and stiffer. However, that was years ago, and when I did start using it, I discovered that it was at least as easy to work with as 2.5mm².
Indeed. In fact, that just about the only situation in which I've used 4mm² cable.And may well allow a 32A radial.
