Hello everyone, just registered and have a big problem.
I have a double glazing company remove a front door & brick up the opening, remove a window approx 9' x 6' and replace with a upvc door. Basically was swapping door over & getting rid of the window.
Problem that was reported from day one, the door was warped tried & failed to be resolved, TS & building control not interested so here I am now.
Had a quote for composite door but at present the wall rocks when door closed hard(not slammed) the door man said I would need it sorted before fitting door as they don't do this work.
The wall is on a large porch area 12 x 10 feet and the door is near the corner(should've been 18" further in but...
How would you suggest I make this stable? The door is about 6" higher than it should be. I was wandering if a frame of 50 x 50mm angle 3m x 1.5m @ 90 deg with a 50mm strap joining the ends to stop it opening sat on the 2 walls with 50mm strap on the inside bolted through be ok?
The outside would hidden by the facia boards and inside hidden by coving.
The frame would be welded with a bolt dropped through the flat bar as reinforcement.
Kevin
Kevin
