Hi all,
Unfortunately its that time of year when the boiler breaks down at first use
Ideal Classic FF240
Think about 10 years old, only lived in the property 12 months.
I returned from holiday and popped the the heating on, there was a bit of a knocking / kettling noise from the boiler.
After a few minutes the boiler cut out, it made a few gurgling noises so i switched it back off.
Now the boiler fires up fine, runs anywhere between 20 seconds and 5 minutes then cuts out.
Then the cycle begins again, the radiators eventually get warm but not that hot.
The old pump (Wilo gold 500) failed just after xmas , a new pump was fitted (Wilo Pico) and it seemed to run fine.
Radiators were also removed at the time and flushed out, Fernox added.
I drained and bled them all again thursday but didnt fix the current issue.
Gas engineer came out on friday, took one look at the boiler (didnt inspect or bring any tools) and said its more than 5 years old, scrap it and replace with a combi.
Wouldnt even investigate the problem.
Had another engineer out today, essentially he said the same... seems they only want to install a new boiler and not fix issues with existing boilers.
I removed the cover to check the fan was spinning as that seems to be a common issue, was spinning but seemed a little noisey.
The heat exchanger however looked quite rusty, photo attached.
Now im not looking to fix the issue myself, just want to know what the likely fault is and whether its fixable?
Any help greatly appreciated.
Im located in Leeds if anyone knows a recommended engineer to take a look
Ideal Classic FF240
