Hi all,
I've recently had to disconnect the electric running to my shed whilst it was replaced.
The set up to the shed is a 2.5mm SWA cable spurred from an outside socket which is fed from a 16A radial in the house (RCD protected).
The SWA is terminated in the shed via another RCD, on to a FCU (13a) and into 1 double socket and 1 light.
A few things I noticed:
The SWA armour is not earthed either end but does have a cpc (3 core cable) - the glands used at both ends are of the plastic type with the armour cut off / stripped back.
The RCD in the shed seems to have the live/neutral swapped (L is clearly marked but has the neutral wire in)
All of the above was installed by an electrician during my rewire.
Should I be concerned, especially about the RCD? Shouldn't something like this have been identified during testing?
And to top if off I've just found out the rewire hasn't been notified to BC or NICEIC (despite them being registered!)
Any help appreciated
Thanks!
Thanks!
