It wouldn't be undersized (if designed properly).
Maybe not (and I'm not sure what you mean by 'undersized'), but it's electrically no different from doing the same with an unfused spur from a ring final - and, for what it's worth, it is one of the options shown in the infamous Appendix 15.I would never occur to me to ever, ever, ever use an undersized cable for a branch on a radial.
I believe that it would.It wouldn't be undersized (if designed properly).
That is true, but that has no bearing on my opinion.Maybe not (and I'm not sure what you mean by 'undersized'), but it's electrically no different from doing the same with an unfused spur from a ring final
Nor that.and, for what it's worth, it is one of the options shown in the infamous Appendix 15.
That's a perfectly reasonable personal opinion for you to have but, since it is apparent that not everyone shares that opinion, I'm not sure that your language ("one should always, without exception ...", twice) is necessarily appropriate.One should always, without exception, be able to connect any number of new sockets at any point in the circuit, and one should always, without exception, do so using the same size cable as was already being used, in order to preserve the ability to always, without exception, connect any number of new sockets at any point in the circuit.
So, back to square one.Replace a socket with a FCU and you can then add sockets protected by the FCU it really does not matter it the socket being replaced is fused spur, unfused spur, radial, or ring final if the socket being replaced has been fitted correctly in first place there will be no problem.
