The blues are your problem, they needed to be connected together and to the light fitting. The loose one is probably the supply. Also I can't tell if there's anything connecting the three terminals of the live block together? Otherwise they will not be connected together. You need to either feed them into a single terminal or connect them together on the other side with short bits of conductor.
You also need to sleeve the CPC (earth) conductors fully and separately)
Yes all what you said is fine. Good luck, don't forget to switch off the mains first!Thanks, so just to clarify connect both the blue wires into the new black connector box for the new fitting.
The live block terminals aren’t connected together, can I just connect all 3 of them into a single terminal of the same type or do I need a different kind of terminal?
Sometimes I wonder why we bother…Have you not read any of the replies?
Not everyone should attempt their own electrical work.not everyone is as good at absorbing information as you'd hope
Competence in electrical work is clearly not present.
The OP needs an Electrician. Competence in electrical work is clearly not present.
