So now its really about earthing that piece of pipework in the kitchen or not and there are various schools of thought on that within this thread
Indeed, and those differing schools of thought exist because it is a 'swings and roundabouts' situation, and different people will have different opinions about which of two possible scenarios is the more likely.
Pipes, per se, are not much of an issue, since they are rarely touched directly (and are often not very accessible to be touched). There is much more to talk about when the metal pipe connects to easily-touchable metal, such as a metal kitchen sink. There are then two possible scenarios to consider, both arising if an electrical appliance (kettle, toaster, blender etc.) becomes faulty, or a cable becomes damaged, such that touchable parts of it become 'live' ....
1... that live part comes into contact with the metal sink (or whatever). A person then touches that sink at the same time as touching something else which is at earth potential.
2... a person comes into contact with the live part at the same time as touching the sink (but nothing else).
In case (1), if the sink is
not earthed, the sink will remain live, so that a person touch it and something earthed will suffer a shock. If the sink
is earthed, then a protective device (RCD, MCB or fuse) should operate as soon as the faulty object comes in contact with the sink, so that the sink no longer represents a hazard to someone touching it.
In case (2), if the sink is
not earthed, a person touching it at the same time as touching a life faulty appliance should not get a shock - since, although they are in contact with 'live' electricity, there is no path through them to earth. If the sink
is earthed, they will receive a shock, since current flows through them from the faulty device to the earthed sink.
In both cases, if the circuit supplying the faulty appliance/cable is RCD protected, the RCD should limit the duration of any electric shock.
So, if one believes that (1) is more likely than (2), then earthing the sink is the better bet, although it increases the chance of an electric shock in scenario (2). If one believes that (2) is more likely than (1), then not earthing the sink is the better bet, although it increases the chance of an electric shock in scenario (1).
It is differences in views as to which is the more likely scenario which leads to different opinions as to whether or not one should earth a kitchen sink (by earthing metal pipe connected to it), if the pipe in question does not require bonding and which, in the absence of explicit 'earthing' would be 'floating' (not connected to earth.
However, in practice, that last comment makes this discussion almost moot. Metal water pipes are almost always unavoidably earthed, via the CPCs of boilers, immersion heaters, CH pumps/valves etc. etc. and connections between pipes - so the question of whether or not one should ('additionally') explicitly earth the pipe with a bit of wire becomes irrelevant.
