and the lower few feet of some walls.I think there is no doubt that, in some situations, a solid floor (particularly of an outhouse) can qualify as an extraneous-c-p
there is some conductvityare surely connected by the conductive water within the pipe
fill it with water and measure its resistance.
Not sure what you're getting at there, this isn't like a lake where the water has loads of parallel paths (our the earth) so you want to spread them to get better conductance. The size of the path is 3.1x36 and is 1m long. The conductive end pipe at each end only needs to be a couple of cm long as the water to copper boundary isn't any less conductive than water alone.Use at least 100 cm of copper pipe at each end of the plastic pipe as the electrodes.
Yes but there's a big different between a pin point and 100cm of copper pipe. A few cm would be ample.Test with only the pin point end of a multi-meter probe in contact with the water and the conductivity is limited by the cross-sectional area of water in contact with the probe orrespective of the cross sectional area on the water in the pipe.
Did you mean 100 mm Bernard?Use at least 100 cm of copper pipe at each end of the plastic pipe as the electrodes.
This is very interesting..............let's say a cable near my kitchen copper pipe becomes bare and the live touches the pipe, that pipe then becomes live, but it's connected to the blue plastic incoming main, but the copper is connected to earth via the not very conductive water.................will this reduced conductive link to earth be enough to trip the breaker?
