You're right Jad, but you can't knock a man for being interested in a subject and wanting to know can ya?
Not at all
You will have but -if I have a house with all copper water pipes and I attach a bonding clamp and a 10mm cable to that and the MET, surely you have just earthed all your water pipes
I don't understand that bit.(not that they needed it because they were already earthed by the metal pipes)
What the {whatever} has the type of supply earthing got to do with this?Look up PME and read up on that.
Please don't pretend that all of those schools of thought are equally valid.So now its really about earthing that piece of pipework in the kitchen or not and there are various schools of thought on that within this thread
You're a total d*ck you are. It has everything to do with it with regard to the more recent discussion but you wouldn't know that as you probably only read and remember things you think you can be "clever" about and both options are valid in light of the fact that you have never seen nor tested the install you two bit to**er.What the {whatever} has the type of supply earthing got to do with this?
LOL this is still going. Look up PME and read up on that. The thing that you raised though originally is not to do with that though as like you say the incomer is plastic. So now its really about earthing that piece of pipework in the kitchen or not and there are various schools of thought on that within this thread
I never said it was so not sure why you quote me there?Bonding is not earthing. You do not bond metallic pipework to protect against a damaged cable rubbing up against the pipes - that condition is no different to you grabbing hold of the damaged cable. Bonding is there to create an equipotential zone within the electrical installation.
The OSG is not the regs though. You should be competent to understand what the regs mean. Why would you want to 'earth' a bit of pipe that is not going to introduce a potential from outside the installation? Do you earth door handles, cutlery, scrim beads?I don't say earthing and bonding are the same there and its all getting a bit pedantic to be honest. Bottom line is OSG say it should be bonded unless certain criteria are met and can be confirmed, meaning its safer to do it than not . People here disagree without seeing it, which is fine I may add that's their opinion.
I don't think that logically follows from your premise.OSG say it should be bonded unless certain criteria are met and can be confirmed, meaning its safer to do it than not .
The irony here is that the original post was clearly, concisely, and correctly answered by none other than ban all sheds in the second reply to this topic.I think most of the confusion here is because I for one am trying to keep it in context to the original post
The metal pipework is likely to be run with and not separated from cables and should a line fault to the metal pipework occur due to a pinched cable for example then as you rightly put the 'earth' path to that pipe will aid in the ADS on the faulty circuit. If it wasn't earthed then that pipe would be live so imo its better to have it. To indulge your derisory examples its extreamly unlikely these will have contact with a live cable.
I'm no fan whatsoever of his bedside manner nor helpfulness, but on factual matters he is rarely incorrect, and apologises immediately when proven wrong.
Cables are double insulated. As said earlier - do not make something part of the electrical installation that doesn't need to be. If you do as you propose, you would now have the opposing issue whereby if there is a fault with the electrical installation (earth fault, lost neutral etc), the pipework could become live where it wouldn't have before.
The regs already account for installation methods, mechanical support and separation of electrical and other services.
