Car pollution - Interesting
"you should only be able to buy clean-burning stoves"
is not the same as
"stoves to be banned"
How to write a headline
- make it short
- make it snappy
- make it up
show me first the document where you think he said "I want to ban wood burning stoves"
(you won't)
it's not in here
https://www.london.gov.uk/city-hall-blog/mayor-demands-more-powers-cut-pollution
This is on the page you just posted : ''Reforming the Clean Air Act to set tighter emission limits for wood-burning stoves and create zones where the burning solid fuels is forbidden '' as one of the key objectives.
So, how exactly can a work burner work where the burning of solid fuel is prohibited?
I see there is now a concern about pollutants in the air on the London underground.
Apparently 1000 x higher levels than a main road!
I've pointed out the error.
Sadiq Khan is not banning wood burning stoves.
Let me point out your error:
There is no post in this thread that says Sadiq Khan is banning wood burning stoves.
You spend your time twisting what has been posted to suit your point scoring agenda. :):):)
The discussion was about whether Sadiq Khan wanted to ban wood burning stoves. Clearly, he does not. He only wants to ban the inefficient, smoky ones.
Hawkeye claimed he wanted to ban (all) wood burning stoves, citing newspaper articles. Evidently, that is not correct.
Interestingly only last month the mayor of London called for a ban on wood burner's.
Air pollution: Sadiq Khan calls for ban on wood-burning stoves
For you to then intimate that anyone had claimed that Sadiq Khan is banning wood burning stoves is nonsense.
You are either intentionally trying to mislead, or have misunderstood the discussion yourself.
So you are either being deceitful, or you are incompetent. Which is it?
yep JD and way har bee spend there time altering & twisting posts & quotes so as to fit in with there extremist agenda
nasty pieces of work the pair of em :)
From the guardian article:
https://www.theguardian.com/environ...diq-khan-calls-for-ban-on-wood-burning-stoves
The mayor has asked the environment department to amend the Clean Air Act to allow for the creation of zero-emission zones where the burning of solid fuel is not allowed from 2025 onwards.
John, perhaps you can answer directly to my two posts above, because it appears you may be wrong.
Nasty old transam calls this twisting
nasty JD always twisting & altering quotes / posts ;) (bitter twisted duffer :))
answer Hawkeyes question , or is there a problem :LOL:
